Houdini destruction RnD
hideoncyka
Hello everyone,
So I finally finished that one, took me a little big longer that supposed to, but that's to due to the fact that I had to figure out couple of the stuffs.
This is rather a prepration of destruction workflow in Houdini before digging deeper in something more serious.
Here's the link -
Thanks,
Depends what do you mean, all in all it's farily simple setup that uses pop advect by volume as source for force pushing the pieces apart.
3 sets of constraints glue for holding stuffs together, hard for bend inside structures and conerel for a little bit of stickness when the glue constraints gets broken.
I can share the scenefile, but unfortunately can't give away the model as I bought it.
  • 2 weeks later...
Hi Grzegorz,
your sim looks great! I’m having a hard time learning how to use different constraints for RBD. If you could share a scene file of this, even without the model of the house, I would really appreciate it :)
Thanks and keep the good work!
  • 2 weeks later...
