copy low res position to hi res
ceci
Hi, I have a simple rbd setup where a ball hits the ground,
I 've created a low res version to sim, using polyreduce and would like to transfer the information to the hi res pieces.
I've tryed copying the primintrinsic 'pivot' and 'transform' and 'P' attribute. The hi res geo moves to the pivot of the low res witch is slightly different.
Any one knows how to fix this issue?
I've attached the file.
Thanks so much,
Ceci
copy_position_to_hi_res.hipnc
