Mantra rendering statistics
it goes to console that will pop-up as a separate window. you have to enable "output to console" option on rop driver too. it's not enough to dial a number on verbose slider in reder statistics. annoying.
Hi, David, thanks!
A bit confused here... I can`t find "output to console" option. I can`t find the Statistics tab in docs.
And after submitting the render I close Houdini to save memory, shouldn`t console window close with Houdini as well in this case?
Or maybe I render my shots in the wrong way?
Edited by kiryha
hm... it certainly works for me. I remember thou, at some point this was broken and the solution was to force the console pop-up in houdini.env config file. i think the env variable for this is
HOUDINI_WINDOW_CONSOLE = 1
i'm not on windows now so can't test it... check this docs page anyways: http://www.sidefx.com/docs/houdini/ref/env.html
  • 8 months later...
I also don't get console when I render to disk in background... only when I render to disk or render to mplay.  I thiiiiiink that's because the -o consolewait flag doesn't get passed along to hbatch.  If you look at the tooltip for Command under the Driver tab it says "This will be disabled if the IFD file is saved to disk."
Probably the easiest way to get logs from background renders is to not use the GUI:
http://www.deborahrfowler.com/HoudiniResources/Overview-CommandLineRendering.html
https://houdinitricks.com/command-line-rendering-in-houdini/
Edited by xxyxxy
