Macros and hotkeys in Houdini
Hey there.
I would like to record a series of UI commands and replay them via a hotkey.
Coming from Modo I have macros in mind but not sure what is the equivalent of that in Houdini. Can someone point me in a right direction?
For now as a very simple example:
I just want to have the F1 key assigned to "Restart playback from first frame" so essentially Stop > Go back to frame 1 > Play. Right now this would be Shift Up, then Up which is inconvenient and requires two hands.
Hitting F1 would be tremendously useful during tweaking my simulations.
Thanks!
Kristof
Ohh yesss! Exactly what I wanted.
Here's the code, I'll just leave it here as a solution in case anyone stumbles accross this:
def outputPlaybarEvent(event_type, frame):
    if event_type == hou.playbarEvent.FrameChanged and frame == 1:
        print event_type
        hou.playbar.play()
        hou.playbar.removeEventCallback(outputPlaybarEvent)
    return False
hou.playbar.addEventCallback(outputPlaybarEvent)
hou.setFrame(1)
You could even make it a start/stop toggle:
        #print event_type
        hou.playbar.play()
    return False
if not hou.playbar.isPlaying():
    hou.setFrame(1)
else:
    hou.playbar.stop()
Edited by garf
