Deadline & Houdini File Path
zinogino
Hey everyone,
So just started deadline for Houdini and I've managed to send my rop output to deadline for rendering but when I explore the output file path, it shows file does not exist.
However, when selecting the explore file path, it opens the correct pointed file directory where I want my caches & renders to be at.
It does work if I copy & paste the output file path
I'm using $JOB for all my files since I'm working, rendering, caching off our servers.
Our IT guy have no clue on why it's behaving like this as well therefore would be best if anyone can guide me in setting up deadline?
Screenshots attached
H16.0.633 | Deadline 10.0.19.0
  • 5 months later...
Hey, Zino!
I think now I'm having the same issue as you. I submit job to deadline but render output files are missing when I try to use redshift.
No problems if I submit mantra or cache jobs to deadline.
Did you find a way to figure this out?
Will be glad if you share.
On 9/11/2019 at 7:09 PM, ibotatar said:
Hey, Zino!
Hey there, sorry for the late reply.
Couldn't get the ROP deadline node to work so ended up just using the submit houdini to deadline on the top render menu.
Talked to the engineer who runs our deadline farm and he has no idea on it as well.
Hope this helps!
  • 9 months later...
On 16/09/2019 at 3:46 AM, shiki777 said:
I have the same problem, did you found the solution yet?
Found the solution:
  1. Make sure the plugin version matches the current Houdini version
  2. Frame per task should be set higher compared to the submit frame range (usually I just set to 9999)
  3. Use $JOB instead of $HIP, make sure paths are all set correctly
Hope this helps.
