Flip inherit velocity H17 - Beginner
REC
What is the best way to add velocity to an Alembic (animated) flip object? I want my flip particles to be advected as the object moves. All tutorials I look at are using H16. I know there are a few threads about the new workflow in 17 but I can find one for flip.
Any help will be appreciated.
Thanks
I have added a point velocity sop after the Flip Source (create surface). The velocities are going all over the place seeing that the Flip Source is changing frame by frame. If I bump up the frame sample to 10 in the point velocity sop I get a fairly stable velocity but there is still some movement from deforming Flip Source. I think I will go with this for now. Scene file attached.
I have also taken a look at example file below but this is super slow and still using the old fluid source. This is a bit over complicated for what I need.
http://www.sidefx.com/docs/houdini/nodes/sop/trail.html
SpinningFlipCollision Example for FLIP Solver dynamics node
Any advice on doing this better will be much appreciated,
test_vel_upload.hip
