tr3c00l Posted April 8, 2019 Share Posted April 8, 2019 (edited) Hi! I am totally new to Houdini and just starting to get the hang of it - and I am stuck on one problem. I have different objects each with a different emission shader applied. Is it possible to create a custom emission aov for each shader? Meaning I'd like to have the emissive direct AND indirect contribution of each shader on all objects - basically a light aov, just for emissive shader. Using Houdini 16.5 and Mantra. I'd probably would need to use LPE which is not included in Houdini 16.5 yet if I am not mistaken. Thanks for your help! Cheers tr3c00l Edited April 8, 2019 by tr3c00l Quote Link to comment Share on other sites More sharing options...
woodenduck Posted April 9, 2019 Share Posted April 9, 2019 Mantra/Images/Extra image planes/Surface emission color Quote Link to comment Share on other sites More sharing options...
tr3c00l Posted April 9, 2019 Author Share Posted April 9, 2019 Thanks for your answer! But that gives me just the emission color of the emissive objects - and of all emissive objects in 1 AOV, right? I'd like to have the emissive contribution to the scene from each emission source in a separate AOV. Quote Link to comment Share on other sites More sharing options...
woodenduck Posted April 10, 2019 Share Posted April 10, 2019 I think what you are after might be called "indirect emission" in Houdini. On the Extra Image Planes Tab, if you scroll down to the Extra Image Planes parameter and hit the "+". Then in the VEX Variable parameter enter "indirect_emission". I think that might be what you're looking for. To get the emission per object you will have to render them separately. Cheers, WD Quote Link to comment Share on other sites More sharing options...
anim Posted April 10, 2019 Share Posted April 10, 2019 You may be able to replace your emissive objects with Geometry Lights and do per light exports Otherwise H17+ and LPEs may be the other option Quote Link to comment Share on other sites More sharing options...
