Chop Reference Issue [SOLVED
My first time messing around with Chops outside of just adding some easy adjusting with motionfx. I'm testing it out just trying to move a sphere with some audio, what am I doing wrong? I appreciate any and all help, thanks.image.thumb.png.54704da1f9f3af635d7fab771d5fdadf.png
My values aren't super small, I feel that they should be noticeable.
Here I'm doing "   chop("/obj/chop_music_OUT_music/")     "
is this not the correct way of referencing the node within chops? / getting the audio data ?
I feel like I'm making a dumb mistake somewhere but I've been stuck for a few hours, any help is welcomed.
If you guys have any links to more recent tutorials covering that topic that would be helpful as well, thanks so much.
Edited by MitchFields
as you can see in the example you need to specify the channel path, not just CHOP node path
so in your case
chop("/obj/chop_music/OUT_music/chan0vol")
or
chop("/obj/chop_music/OUT_music/chan1vol")
also alternatively you can directly export channels to parameters from CHOPs, similarly to what Motion FX do
