impact data after sim
waltt
Might be a stupid question, but is there a way to get impactanalysis data from a bgeo sequence?
I created a long sim, client want this exact one, but I didn't add the impactanalysis node to it and now I need to add particles
whenever objects hit the ground..
Not sure if it's possible but maybe you guys know a way. I could add points to the groundplane with an attribute transfer,
and then use those points to spawn particles from, but maybe there's a better option?
Another problem surfaces.. with the intersection analysis I create points, but i want these to dissapear after 1 second, otherwise the particles will keep spawning from these points..
I initially solved this with the particle sop, by setting a life expectance and turning on 'don't reuse points', but this also stops newer particles to spawn from later collisions.
Adding age to points and deleting points based on age doesn't seem to be an easy task..
I attached my test file.
particles_from_intersection3.hiplc
