Stannojj Posted April 26, 2019 Share Posted April 26, 2019 So i'm trying to Cache out my water simulation, I've cached it out previously as a VDB, yet my file sizes are just below 800KB. It's a rather small simulation but i assume that's wrong. How do i go around fixing this issue? WhiteWaterSim.hipnc Quote Link to comment Share on other sites More sharing options...
char Posted May 7, 2019 Share Posted May 7, 2019 Is it only caching last frame? if YES > add $F to your filename. If NO, I'd have to take a look at the file, but can't do that now. Quote Link to comment Share on other sites More sharing options...
Lucy Coleclough Posted May 9, 2019 Share Posted May 9, 2019 Hi mate In your fluid surface node you're converting your particles to polygons. If you want to use polygons then use .bgeo.sc If you want to use VDB's then switch the output mode to surface VDB Quote Link to comment Share on other sites More sharing options...
