isah_voodoo Posted May 4, 2019 Share Posted May 4, 2019 Hello, I have run into a fairly annoying problem that I am able to do in vops but in vex I am not getting the desired results. I am simply trying to subtract the current position from the objects center and set it to v@v It looks like it is subtracting something but the vectors don't look like they are pointing directly at the center. I am doing this: v@P2=point(1,"P", 0); v@v=@P2-@P*22; I have the centroid being plugged into input two of the wrangle. What am I missing here ? Thank you centroid_sub_vel.hip Quote Link to comment Share on other sites More sharing options...
3dome Posted May 4, 2019 Share Posted May 4, 2019 not in front of houdini atm, but I guess you need brackets around (@P-@P2) -> order of operations Quote Link to comment Share on other sites More sharing options...
Sean-R Posted May 4, 2019 Share Posted May 4, 2019 Hi Matt, It looks like it's an order of operations thing. If you wrap @P2-@P in brackets it seems to work fine Quote Link to comment Share on other sites More sharing options...
isah_voodoo Posted May 5, 2019 Author Share Posted May 5, 2019 ah, how could i have missed that. thanks guys ! Quote Link to comment Share on other sites More sharing options...
