MAYA_ Posted May 7, 2019 Share Posted May 7, 2019 Heya! I am looking into compressing down the size of my volumes and I have stumbled across compressing my vdbs down to 16 bit float. This make my guys nice and smaller and I don't see any difference in rendering but I am not 100% understanding whats happening behind the scenes here. Is there any disadvantages to doing this, such as loosing res? I would be happy if someone could help me out with this! Thanks Quote Link to comment Share on other sites More sharing options...
celd Posted May 7, 2019 Share Posted May 7, 2019 (edited) Think of it as comparing an 8bit jpg and 32bit exr formats, they capture different ranges of data but can display the same thing. 16 bit volume will have a smaller range but still look correct enough under the right conditions. So its the bit depth of the value of individual voxels. Edited May 7, 2019 by celd 1 Quote Link to comment Share on other sites More sharing options...
MAYA_ Posted May 7, 2019 Author Share Posted May 7, 2019 6 minutes ago, celd said: Think of it as comparing an 8bit jpg and 32bit exr formats, they capture different ranges of data but can display the same thing. 16 bit volume will have a smaller range but still look correct enough under the right conditions. So its the bit depth of the value of individual voxels. Hey celd, thanks so much! This is a lot clearer now I am wondering if this is something studios do in production or if this is a case by case kind of scenario? Just trying to figure out if this is something that I should be implementing into my future workflow, as there is defo upsides to having to store less data. Quote Link to comment Share on other sites More sharing options...
celd Posted May 7, 2019 Share Posted May 7, 2019 I would say it depends on the studio, usually the larger studios should have plenty of space to spare. If you are however really starved for space I dont see why you couldnt do it, just be careful when compressing vector fields like this, I found it can remove too much information sometimes. Quote Link to comment Share on other sites More sharing options...
MAYA_ Posted May 7, 2019 Author Share Posted May 7, 2019 (edited) 25 minutes ago, celd said: I would say it depends on the studio, usually the larger studios should have plenty of space to spare. If you are however really starved for space I dont see why you couldnt do it, just be careful when compressing vector fields like this, I found it can remove too much information sometimes. I see, thank you! Do you recon it would make sense to pull out the fields that might be less important and compress these separately, but leave important stuff as it is? I am mostly trying to save space and making this whole process more efficient with a limited amount of storage for huge scale sims If you have any other suggestions in that area, I would be excited to hear! Edited May 7, 2019 by MAYA_ Quote Link to comment Share on other sites More sharing options...
pclaes Posted May 7, 2019 Share Posted May 7, 2019 Before going into rendering we tend to compress all volumes to 16 bit. There is no noticeable difference for rendering and almost a 50% space savings. Only thing to really be careful with vdb is pruning with rest volumes (they really should not be pruned as 'zero' is a valid rest value.) During the simulation you want the full 32-bit as that accuracy is needed for the fluid solve, but once you are done with the sim (and any post processing) you can go down to 16-bit. 1 1 Quote Link to comment Share on other sites More sharing options...
kleer001 Posted May 7, 2019 Share Posted May 7, 2019 4 hours ago, celd said: I would say it depends on the studio, usually the larger studios should have plenty of space to spare. If you are however really starved for space I dont see why you couldnt do it, just be careful when compressing vector fields like this, I found it can remove too much information sometimes. Sometimes I half the resolution of my velocity fields (double the grid size). But not with density or anything else. 1 Quote Link to comment Share on other sites More sharing options...
MAYA_ Posted May 8, 2019 Author Share Posted May 8, 2019 (edited) 13 hours ago, pclaes said: Before going into rendering we tend to compress all volumes to 16 bit. There is no noticeable difference for rendering and almost a 50% space savings. Only thing to really be careful with vdb is pruning with rest volumes (they really should not be pruned as 'zero' is a valid rest value.) During the simulation you want the full 32-bit as that accuracy is needed for the fluid solve, but once you are done with the sim (and any post processing) you can go down to 16-bit. Hey pclaes! Thanks this is super helpful! I was thinking the same thing but I did not want to start doing this and then get problems when rendering later on that I might not like initially notice. Also yeah this was only thought to be a post simulation, pre rendering thing Edited May 8, 2019 by MAYA_ Quote Link to comment Share on other sites More sharing options...
