Microsolver built according to HDK sample works differently from built-in nodes
So I'm still building some microsolver nodes for water simulation. I noticed that all the microsolver I made including the Gas Add from the HDK sample all have a grey input point on the left. All built-in in gas node do not.
Seems like this doesn't effect the execution result but I'm still curious how do I make a node that looks exactly like the built-in ones.
And also, enable bypass on these nodes doesn't seem to work. Do I need to manually skip in solveGasSubclass()?
  • 3 months later...
  • 1 month later...
