Hongzhu Posted May 8, 2019 Share Posted May 8, 2019 So I'm still building some microsolver nodes for water simulation. I noticed that all the microsolver I made including the Gas Add from the HDK sample all have a grey input point on the left. All built-in in gas node do not. Seems like this doesn't effect the execution result but I'm still curious how do I make a node that looks exactly like the built-in ones. And also, enable bypass on these nodes doesn't seem to work. Do I need to manually skip in solveGasSubclass()? Quote Link to comment Share on other sites More sharing options...
almatea Posted August 11, 2019 Share Posted August 11, 2019 Just add // Make this a microsolver: setGasDescription(theDopDescription); after static SIM_DopDescription theDopDescription( ... (check http://www.sidefx.com/docs/hdk/_s_i_m_2_s_i_m__radial_emit_8_c-example.html) Quote Link to comment Share on other sites More sharing options...
Hongzhu Posted September 18, 2019 Author Share Posted September 18, 2019 On 8/11/2019 at 7:37 AM, almatea said: Just add // Make this a microsolver: setGasDescription(theDopDescription); after static SIM_DopDescription theDopDescription( ... (check http://www.sidefx.com/docs/hdk/_s_i_m_2_s_i_m__radial_emit_8_c-example.html) Expand This worked! Thank you so much Quote Link to comment Share on other sites More sharing options...
