nemsi Posted May 9, 2019 Share Posted May 9, 2019 Hi guys, I would like to creat this kind of powder effect wihtout killing my computer with dreasing too much particle separation of my popgrain... Perhap an other way to do this?.. https://www.pinterest.fr/pin/488922103292391449/visual-search/?x=13&y=13&w=409&h=518 Any hint? Thank you matierePoudre.hip Quote Link to comment Share on other sites More sharing options...
kleer001 Posted May 9, 2019 Share Posted May 9, 2019 You might be able to use Vellum grains and/or split up the whole sim into vertical stripes. Only things I can think to cheapen each pass. Quote Link to comment Share on other sites More sharing options...
nemsi Posted May 9, 2019 Author Share Posted May 9, 2019 I'm studying the vellum way Will post as I get something interresting Thank u. Quote Link to comment Share on other sites More sharing options...
kleer001 Posted May 9, 2019 Share Posted May 9, 2019 You might also want to layer your sims vertically up from the ground plane. Quote Link to comment Share on other sites More sharing options...
nemsi Posted May 10, 2019 Author Share Posted May 10, 2019 Quote You might also want to layer your sims vertically up from the ground plane. Expand Not something I'm used to... Can you explain Kleer001 please? here my vellum version, still need work because it miss some accident, too uniform.. Thank you. matierePoudre_Vellum.hip Quote Link to comment Share on other sites More sharing options...
