Krion Posted May 17, 2019 Share Posted May 17, 2019 (edited) Hi, So I thought I should get to know height fields today, because I have modeled object on which I want to make a terrain with mountains. So far as I understand it height fields are not 'real'; they are just visualisations of height based on the values of voxels on a 2D volume (slice). Okay, but is it also possible to put these height fields onto a existing geometry that is not flat? Is height fields the way to go for something like that? Thanks for your help. Edited May 17, 2019 by that Abstract guy Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted May 18, 2019 Share Posted May 18, 2019 13 hours ago, OdForest said: Hi, So I thought I should get to know height fields today, because I have modeled object on which I want to make a terrain with mountains. So far as I understand it height fields are not 'real'; they are just visualisations of height based on the values of voxels on a 2D volume (slice). Okay, but is it also possible to put these height fields onto a existing geometry that is not flat? Is height fields the way to go for something like that? Thanks for your help. Hi, yes it is possible for geometry shape like grid after mountain sop that is not flat. As you've mentioned heightfield is a volume and you can use an attribfromvolume node to get height value and set this value to Y position of geometry points. height_to_geo.hipnc 1 Quote Link to comment Share on other sites More sharing options...
Krion Posted May 19, 2019 Author Share Posted May 19, 2019 Is it also possible when you have, say, a shape like this? Can you cut out what's in the height field grid which is not the same is this shape (from top view, I guess)? heightfield on such shape.hip Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted May 19, 2019 Share Posted May 19, 2019 10 hours ago, OdForest said: Is it also possible when you have, say, a shape like this? Can you cut out what's in the height field grid which is not the same is this shape (from top view, I guess)? heightfield on such shape.hip This .hip needs more work to do but yes, i think it is possible too. heightfield on such shape_01.hipnc Quote Link to comment Share on other sites More sharing options...
Krion Posted May 23, 2019 Author Share Posted May 23, 2019 Thanks. I'm gonna buy a heightfield/terrain course then, seems worthy. Would still like to know if you or anyone else found out how you can get rid of these spikes. Thanks again. Quote Link to comment Share on other sites More sharing options...
