MSI GL63 8SE laptop
annatronci
Assuming you're not using anything that relies on the older version of Qt, I'd try updating the video card drivers (downloaded directly from Nvidia) and update Windows. If that doesn't change anything then maybe try a vanilla install of Windows instead of the manufacturer provided Windows. If you're using something that relies on the older version of Qt then continue with the version of Houdini, with legacy Qt support, that works.
Edited by lukeiamyourfather
