Vex anoise
Alexanrus
That looks like it should work. But... I find VEX a little tricky with multiplying vectors by floats. It doesn't like to do that right after a function. I suggest assigning the noise to the variable and then in another line multiplying the vector by your float amp. Like:
float amp = 4;
vector noise1 = anoise(v@P);
noise1 *= amp
  • Like 2
float amp = 4;
noise1 *= amp
Thanks it's working
  • 2 weeks later...
when you have vex functions that can output different types, its always a good idea to cast them directly
for example, if you want a random greyscale color, based on the position:
v@Cd = float(rand(v@P)); // this will cast it back to a vector in the end, with the same value for all components.
v@Cd = rand(v@P); // this will cast it back to a vector in the end, but with different values for the components.
