davidyannick Posted May 30, 2019 Share Posted May 30, 2019 Is there a way in Houdini to extrude with shortcuts like in maya ? In maya with W and Shift + direction we extrude an edge R + Shift + direction we inset ... Thx Quote Link to comment Share on other sites More sharing options...
Drughi Posted May 30, 2019 Share Posted May 30, 2019 Not really. The best way is to make your own radial menu. You also can use scripts in radial menus. Quote Link to comment Share on other sites More sharing options...
magbo Posted August 5, 2020 Share Posted August 5, 2020 (edited) Actually, you can press and maintain "c" and a radial menu will appear. Then you can go "Polygons > PolyExtrude". If you want to make it quicker, you can navigate de radial menu with numbers. Therefore try "c + 6 + 6" (it follows a direction logic so it is quite intuitive if you have a numeric keypad in your keyboard). You can also navigate de radial menu with the arrow keys. So you can do "c + -> + ->" (but I don't know how to access diagonaly positioned tools that way). Btw, just discovered this can only (or at least in "Build" desktop mode it didn't work) works in "Modeling" desktop mode. Edited August 12, 2020 by magbo 1 Quote Link to comment Share on other sites More sharing options...
