nicoladanese Posted May 30, 2019 Share Posted May 30, 2019 hey! is there a way of limiting or killing the contribution of pop force in an axis? Quote Link to comment Share on other sites More sharing options...
Atom Posted May 30, 2019 Share Posted May 30, 2019 (edited) Can't you just zero that axis' velocity, inside a popwrangle? v@v.y = 0; Edited May 30, 2019 by Atom Quote Link to comment Share on other sites More sharing options...
nicoladanese Posted May 30, 2019 Author Share Posted May 30, 2019 hey! well this way I set to zero the velocity of the point, while I want to set to zero the contribution of that particular pop force. I just found out inside the pop force there's a geometry vop to set the force, where basically you can do whatever you want with the force resulting from that pop node I'm too used to maya where you don't have access to nodes, they are just black boxes you have to use the way they are designed and that's it. so good in houdini you can basically modify everything just by diving inside and having a look! Quote Link to comment Share on other sites More sharing options...
celd Posted May 30, 2019 Share Posted May 30, 2019 if you unlock the POP force node and go into the noise_force VOP, you can see on the right how it combines the force every frame, there are two bind nodes: one to bring the force into the vop, and second to output it. Between them there is an add node and it combines the force with a calculation from the current frame. If you want to kill the additional force you are adding on one axis, you could drop down multiply node and multiply it with a constant vector - for example (1,1,0), that way it will only add the force on x and y axis. 2 1 Quote Link to comment Share on other sites More sharing options...
nicoladanese Posted May 31, 2019 Author Share Posted May 31, 2019 thanks Filip! 1 Quote Link to comment Share on other sites More sharing options...
