davidyannick Posted June 6, 2019 Share Posted June 6, 2019 I'm beginning my switch to houdini from maya, a simple question, in maya we can select two or more edges and the choose to connect them with 1 or mor cuts, is there a way in Houdini to do the same thing ? Quote Link to comment Share on other sites More sharing options...
walter Posted June 6, 2019 Share Posted June 6, 2019 The Edge Divide node does similar things. Quote Link to comment Share on other sites More sharing options...
anim Posted June 6, 2019 Share Posted June 6, 2019 (edited) Either Edge Divide (with connect points checked) or for full loop Poly Split Node in Edge Loop Mode or Edge Loop Tool in the viewport which will place such Polysplit for you Edited June 6, 2019 by anim Quote Link to comment Share on other sites More sharing options...
davidyannick Posted June 6, 2019 Author Share Posted June 6, 2019 55 minutes ago, anim said: Either Edge Divide (with connect points checked) or for full loop Poly Split Node in Edge Loop Mode or Edge Loop Tool in the viewport which will place such Polysplit for you ok thanks Quote Link to comment Share on other sites More sharing options...
