Object on top
davidyannick
7 hours ago, vicvvsh said:
when you are coping to points Z axis of copy object matches to normal of points if they have one. Because of that you should be aware of how your copy is orienting along Z axis and where normals are directing. Here is more information: https://www.sidefx.com/docs/houdini/copy/instanceattrs.html
boxtp_01.hipnc
thanks for the infos :)
