nuki Posted June 11, 2019 Share Posted June 11, 2019 (edited) I want to get Houdini to fetch 'piece0' from geoB' instead of 'geoA' by modifying the primintrinsics of the packed fragments. Since its possible to alter the 'fragmentname' attrib I assume this would be possible, but I cant find out how houdini keeps track of the 'root' of the packed fragments. Seems like the 'path' attribute doesnt have any effect and geometryid is read-only. I was hoping to find an efficient way to swap low-res sim fragments with their respective high-res versions. Any suggestions? Edited June 11, 2019 by nuki Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted June 11, 2019 Share Posted June 11, 2019 6 hours ago, nuki said: I was hoping to find an efficient way to swap low-res sim fragments with their respective high-res versions. Any suggestions? Why? Is a transform pieces SOP not enough? Quote Link to comment Share on other sites More sharing options...
nuki Posted June 11, 2019 Author Share Posted June 11, 2019 (edited) 9 hours ago, vicvvsh said: Why? Is a transform pieces SOP not enough? It would work, but its not the ideal solution for what I'm after. To tell a bit more about the setup: I generate N uniquely fractured walls first. At that stage they just sit at the origin and I generate hi-rez pieces for each wall there. Afterwards I place the walls, randomly selecting one of the prefractured walls to avoid repetition. Then that goes into the sim. The problem with transformpieces is that my source geo (the hi rez pieces) only contains a single copy of each fragment of each wall. I could use an instance or copytopoints sop to re-place and re-duplicate the hi-rez fragments to their respective lo-rez fragments. However, I was hoping to ultimately swap out the fragments only at rendertime (Mantra) using a geometry shader. I dont see how it would be possible to do the copy/swapping inside a procedural geometry shader and I figured doing it via Intrinsics would be the simplest and cleanest way if at all possible. Edited June 11, 2019 by nuki Quote Link to comment Share on other sites More sharing options...
CiaranM Posted June 13, 2019 Share Posted June 13, 2019 You could potentially edit the primitive intrinsic "unexpandedfilename" if all of your high resolution pieces are saved to disk individually. This can done in vex, but some info can be found here: https://www.sidefx.com/docs/houdini/nodes/sop/packeddiskedit.html This does not have to be done on packed disks only, but also works fine on packed gometry. 1 Quote Link to comment Share on other sites More sharing options...
nuki Posted June 15, 2019 Author Share Posted June 15, 2019 Neat, exactly what I was looking for! I suppose there is no similar workflow to use with Packed Memory Primitives? Quote Link to comment Share on other sites More sharing options...
CiaranM Posted June 17, 2019 Share Posted June 17, 2019 You could try using the "op:" syntax to point to an operator in the scene. Never tried it though... Quote Link to comment Share on other sites More sharing options...
