Houdini Animation -> UE4: rotation keyframes wrong?
ron2812
Hi there!
I made a simple rotation in Houdini in OBJ level and exported it via File/Export as FBX file to import into UE4.
The object is rotation 300° over 96 frames.
When I import then FBX into UE4 everything looks fine, but the object only rotates for about 60°?
The same FBX works fine when I test it in Unity.
Is there something I'm missing?
Import settings in UE4 look fine - how can it be that the object doesn't do the full rotation? The imported frames are 96 as well - so that's fine.
Easy in/out looks correct as well. It just doesn't rotate the full 300° but about 60°.
Thanks in advance!
Best,
Ron
