Instantiate and animate objects along curves
  • 2 weeks later...
You could do that in chop, but it is not necessary, there are plenty of ways to do that, with vex / vop, sop solver, or even only in sop. Here is one proposition:
- Create a line on x (length 2 for example)
- transform it on x by 1
- resample it to max segment length 0.02 to get enough points
- copyandtransform total number 8 for example and rotate by 45 on y. It gives you a circle of lines not touching but pointing to the center
- attributevop add a 3D turbnoise to the current position (amp 0.5). Randomizes a bit the shape of th curves.
- create a foreach primitive and create Meta Import Node
     place a carve, animate the firstu from 0.99 to 0 from f0 to f75 for example. This will animate the curve over 3 secs.
     blast 0 delete non selected to keep only pt0 that is the last point is this example.
     copytopoints, plug the point in second input and a sphere in first input (scale 0.1 for this example). This will copy a sphere on each pt0 of each curve, so on the last point of each curve
     timeshift $F-5*detail("../foreach_begin1_metadata1", "iteration",0). This will offset each animation of curve by X frames.
- merge your curves from before the foreach and the output of the foreach (so the spheres moving). So that you can see the sphere moving along the curves.
This is a cheap method because it would become heavy in big scenes and you don't have a huge control but it works for what you want to do.
To build a full system, I would probably have done a vex setup using primuv or curveu attributes to make the sphere move along the curve / geo.
I hope that helped, have a good day!
