Add velocity into Alembic loaded from external.
saca
hi,
the particle shape from other DCC tool with alembic file format,
the alembic do not have velocity data.
particles count changed frame by frame (has life-span, are delete by age), connectivity class id is changed frame by frame,
thus, i cannot track the velocity.
Alembic(delay_load?) -> Connectivity ->Trail(recompute_velocity)
do you have any way fo this case?
thanks
  • 3 years later...
If you have a consistent identifier on the points like 'id' value or similiar that doesn't change every frame then it can be done; if not and the point count changes every frame, then not really.  You can try uploading your file here, perhaps someone has a new solution to this old problem -it happens more than you'd think ;)
