Procedural Wedding Cake
Steven991
Hello, I'm trying to replicate a Procedural Cake I've seen in this video:
To make the basic structure I've created a line with a pscale gradient attribute on each point. Then with a For Each Point loop I copy a cylinder (wich is already scaled in height of the distance between the line points) to the points. The problem is that I want that each layer scales in X and Z according to Pscale, but this is scaling me also the Y of each copied cylinder, which I don't want, as they have to be all the same size (and before copying them they have the right Y). Any ideas on how I can do this? Thank you very much!
Here is another method of copy-stacking any kind of object on top of itself.
houd_stack_copy.jpg.a27d9369c45e9602e6d6211127132472.jpgcopy_stack_object.jpg.c6ac1fc2ef3569d45d6d2d50df160bcc.jpg
After sorting line points by height you can toggle between keeping proportions and a custom ramp shape (left).
vector pos_next = point(0, 'P', @ptnum + 1);
float height = pos_next.y - v@P.y;
float grad = 1.0 - ( @ptnum / float(@numpt - 1) );
float radius = chramp('shape', grad);
if(chi('proportion_keep')){ v@scale = vector(height); }
else{ v@scale = set(radius, height, radius); }
if(@ptnum == @numpt - 1){ removepoint(0, @ptnum); }
Incoming objects are scaled to unit size with 1/$SIZEY and floored with -$YMIN in a transform node before copying.
stacked_copies.hipncUnavailable
Edited by konstantin magnus
  • Like 3
