Seeking Solver Writing Advice
Lucy Coleclough
Hello there I am just getting into solver writing.
I am self taught and as such I have a fair few holes in my knowledge
I aim to build a material point method solver for use in a mud flow effect such as this: https://www.youtube.com/watch?time_continue=42&v=jjeCDYvGJS8
To get to grips with a basic solvers I have built a mass, spring cloth solver: https://vimeo.com/343112353. However there are a few things I've come across that I can't find solutions to.
Every timestep I am accumulating a force vector on each point and then I find the acceleration using a=f/m. I find the velocity v=v0+a*@TimeInc. And I find the displacement using r=r0+v*@TimeInc.
This works quite nicely however I can't shake the feeling that the equations are completely wrong. Everywhere I look they mention using integration in order to find the displacement but it seems like a linear equation to me. Is this wrong and if so what should I be doing?
I would also like to know what the gas integrator node does internally as I find it a bit of a black box.
Many thanks
George Coleclough
while it is a black box, you can at least estimate what it is doing depending on the simulation method set on the node: Euler, Midpoint, RK, ...
so if you research those simulation/integration methods, you may get a better idea what's going on
various game dev articles are a good source of such knowledge
  • Thanks 1
I am not great at maths, but isnt 'accumulating' values in a solver node simply euler integration? Since your r depends on v and v depends on a which you are accumulationg, I'd say you are already using an integral to find the displacement. I'd love if someone confident in this matter could verify this.
Edited by nuki
Thanks, I agree, I definitely need more research into integration methods, I'm following a few courses on youtube. Ill have a look at the articles.
Thanks. I'm not confident in this topic myself, I always thought the result of integration was a function but I may be mixing it up with derivatives. In the pop solver in houdini they calculate the velocity in a similar manner but within the substep they use the gas integrator node I believe to calculate the displacement however I assume this would just be r=r0+(V*@TimeInc).
