domsewell Posted June 30, 2019 Share Posted June 30, 2019 Hi Guys, Im trying to achieve this stepped layering effect on my mesh and figured the correct approach woould be to use a shatter boolean with multiple cubes (which i have colored differently) and then transfer my Cd attributes across however although i am getting the hoirzontal cuts across my mesh in the correct place as intended, the color transfer is offset (almost as if my exactly half of the original cubes height) Why is this occuring / how can i make sure the color transfer occurs only between the cut lines ? Thank you Quote Link to comment Share on other sites More sharing options...
anim Posted July 1, 2019 Share Posted July 1, 2019 probably because the color is taken from closest point and that's probably somewhere on the side of the cubes so if you want the color within the cube volumes you'll have better chance if you attribtransfer colors from colored cube center points if they happen to be along the single line Quote Link to comment Share on other sites More sharing options...
domsewell Posted July 2, 2019 Author Share Posted July 2, 2019 21 hours ago, anim said: probably because the color is taken from closest point and that's probably somewhere on the side of the cubes so if you want the color within the cube volumes you'll have better chance if you attribtransfer colors from colored cube center points if they happen to be along the single line Hi Tomas, Thank you for the reply, i am finding it hard to grasp the technique which you are describing could you perhaps provide an example file? thank you so much Quote Link to comment Share on other sites More sharing options...
anim Posted July 3, 2019 Share Posted July 3, 2019 here is an example, I created boxes based on the points, but you can create points from boxes too if you need it that way cut_by_boxes.hip 2 Quote Link to comment Share on other sites More sharing options...
domsewell Posted September 15, 2019 Author Share Posted September 15, 2019 Hi @anim , Just posting to tie this topic up and say thank you i realise i never got around to replying in the thread. Your explanation was perfect and solved any outstanding issues Thanks again! Quote Link to comment Share on other sites More sharing options...
