UVs for procedural corals
hmihalis1
Hi there,
I'm making some proecural corals for a game engine situation using VDB advection:
so of course the highpoly models need to be reduced and have normals and height etc maps baked, but i'm having a bit of a nightmare trying to find a auto UV solution that can create Uvs that don't contain errors, see below a baked AO texture resulting from auto UVs, the errors are even more noticeable on the normals channel:
5d1e0216de7cc_AOuvserrors.JPG.6a2deecf520e97889f4cf6a1ace3536a.JPG  normals-errors.JPG.ec26717063437c86f2db78831ebbfa79.JPG
Could anyone advise me on what settings to try in the autoUV SOP? I'm currently using the UV autoseam, I tried cluster but its just crashing my machine. It doesn't matter if it takes an hour+ to generate the UVs for each coral, or should I just abandon trying to autoUV shapes this organic and weird? UV maps are always very confusing for me.
Any help at this time is hugely appreciated,
H
Yeah. Basically, just dilate it out so that you can use the ray sop to project it back when you got acceptable UVs.
Auto uv set to cluster with a low number of cluster has worked well for me in the past.
Might also slice up your mesh and the UVs one piece at a time.
