andmotion Posted July 14, 2019 Share Posted July 14, 2019 (edited) Hey, I have several rbdpackedobjects all colliding with each other. I would like to limit the velocity for one of them.....and I could not find the right solution. I use POP Speed Limit but it's affecting all rbd , even if I play with Geometry Bindings I can not get the proper solution..... Thanks in advance for any help:) Edited July 14, 2019 by andmotion Quote Link to comment Share on other sites More sharing options...
bunker Posted July 14, 2019 Share Posted July 14, 2019 You can use the "Group" field in the POP Speed Limit, and type your piece number there. Quote Link to comment Share on other sites More sharing options...
andmotion Posted July 14, 2019 Author Share Posted July 14, 2019 Hey Bunker. How to create group from Rbd Packed Object and pipe that in to the group field inside Pop speed limit ? Quote Link to comment Share on other sites More sharing options...
anim Posted July 14, 2019 Share Posted July 14, 2019 Either put there point number s of packed rbds you want to affect Or Put there adhoc group pattern like: @name=piece2,piece3 Quote Link to comment Share on other sites More sharing options...
andmotion Posted July 14, 2019 Author Share Posted July 14, 2019 On 7/14/2019 at 7:59 PM, anim said: Either put there point number s of packed rbds you want to affect Or Put there adhoc group pattern like: @name=piece2,piece3 Expand Thanks anim Working as it should now. Thanks:) Quote Link to comment Share on other sites More sharing options...
