JJ FX Posted July 15, 2019 Share Posted July 15, 2019 (edited) So, can I somehow increase the number of displayed code lines in a wrangle? Scrolling down has become frustrating... Edited July 15, 2019 by JJ FX Quote Link to comment Share on other sites More sharing options...
flcc Posted July 15, 2019 Share Posted July 15, 2019 Opening the script editor (Alt+E in the field code) ? Quote Link to comment Share on other sites More sharing options...
JJ FX Posted July 15, 2019 Author Share Posted July 15, 2019 1 minute ago, flcc said: Opening the script editor (Alt+E in the field code) ? Yeah unfortunately script editor has limit dimentions for size, I cannot go full screen. And it does not open as another tab so get annoying because it keeps going "behind" other windows. Quote Link to comment Share on other sites More sharing options...
ikoon Posted July 15, 2019 Share Posted July 15, 2019 The snippet parm in the Wrangle is a String Parm, Multi-line String, and it has a tag named "editorlines". That tag is set to 8-30, so the maximum displayed lines is 30. It is a "factory" default, and that Attribute Wrangle HDA definition is in the Houdini installation directory. You could probably redefine that factory HDA (my terminology here is probably incorrect) by right clicking on the node and then "Type Properties..." and saving to another library, which will override the factory one. For me it is a thin ice, I don't want to do it Just for an illustration, I just I duplicated the Parm interface and set bigger "editorlines" in a spare parameter: 2 Quote Link to comment Share on other sites More sharing options...
