JJ FX Posted July 19, 2019 Share Posted July 19, 2019 Hi, Can I somehow create a logarithmic slider that goes from -X, 0, X? Where the function "slows" down both ways close to ZERO? Usually I just create additional switch, that will multiply the value by "-1". But in some areas you want to actually key the parameter, then give it some opposite value (what I mean is that its multiplied with -1). So you have to key the switch and the slider. Quote Link to comment Share on other sites More sharing options...
tamagochy Posted July 19, 2019 Share Posted July 19, 2019 make ramp from 0 to 1 then fit ramp from -x to x Quote Link to comment Share on other sites More sharing options...
