Glue constraint warning - "Required data Glue not found or the wrong type."
Hi there!
I've tried to wrap my head around why this isnt working. Would like some eyes on it as it's not clear as to what I am doing wrong. Following a destruction tutorial and noticing my glue constraints are not showing up.
Here is my packed fragments with proper names on the points:
Next step I unpacked, promoted the names from point to primitive and I can see the constraints with correct primitive attributes:
In my Dop network, I have the Constraint Network pointing to the correct sop path and insterted the correct data name on the Glue Network Relationship node. I see a warning saying "Required data Glue not found or the wrong type":
Any ideas? I am using Houdini 17.5
Thanks!
Edited by hotdoggyurkeyam
added error info
