vdb vel combine
isah_voodoo
Hello,
I am creating a couple of  volumes with the vdb from particles node and I realized that I have no idea how to combine my velocity fields into one. I am trying to use the VDB combine and VDB vector merge . But it is not working. When I visualize my velocity field. It doesn't look right. Someone please help.
vdb_velocity_combine.hip
Hi, you should just use VDB combine and not VDB vector merge. Just plug two volumes at the time in the input A and B , then switch Operation to "Add"
VDB vector merge is for merging vector volumes that have been split for some reasons, for example when you have 3 volumes that are named @vel.x, @vel.y, @vel.z
Edited by Andrea Sbabo
What you are doing wrong is how you connect the two inputs. Apparently is not possible to connect both the A input and B input to the same merge node. The node than don#t know anymore what is what. Also you don't need to specify Group A and Group B
vdb_velocity_combine2_fix.hip
Edited by Andrea
