realitic animate cloud
jeffery
hey guys,
I want ask for some help,I want to make the animate cloud,I try to use cloud noise and volumevop to add noise,and give some animation like $F $T and so on,but the result is not realitic.
could someone give me some good idea to make this?
there is reference:
https://vimeo.com/350898185
https://vimeo.com/350898932
thanks
Edited by jeffery
Build your cloud as you did, create a velocity field and then use vdb advect to move the cloud.
For move complex animation like in your 2nd example you will need a real sim.
Edited by Drughi
OK,I will try to make a real sim later,thanks for your advice.
If you want to spend money here you can buy a file. I bought it myself. The setup is cool, but its very simple and not really realistic. If you want to make a realistic cloud you need to do some research on how clouds really evolve.
OK,thanks guy.
