Load QT UI from HDA extra file
IIIROFLIII
Hi everyone,
I wonder if someone has already succeed to load a .ui file made with qtdesigner, but the particular case is that .ui file is inside a HDA in Extra Files. I've tried with opdef but it seems to be not working.
the command I used was QUILoader().load(path.ui) (and it's working if the .ui file is on disk)
Thanks to all
Hi Salkerx777, thanks for your reply.
I just checked your hda and it seems to have what i'm missing, nevertheless when i try to launch the ui there is this error (see attachment)
From my side I find a "solution", i can get the content of the ui with hou.readFile(opdef....), then write this content on the desktop in a ui file and pointing on it when launching, then deleting after the ui.show() (so it's transparent for the user)
But your solution is more convenient^^, and i'm very interesting to work with it
I dunno guys, just tried it on a different computer and it also works. Both are Linux machines though.
In general, you want to generate Python code from your ui files. See this:
https://doc.qt.io/qtforpython/tutorials/basictutorial/uifiles.html
Houdini ships with pyside2-uic though I couldn't find the wrapper script for it, you can call it directly like so:
hython $HFS/python/lib/python2.7/site-packages-ui-forced/PySide2/scripts/uic.py dialog.ui -o dialog.py
