DOPs not reading Vellum constraint position after object transform
vitols
Ran into an issue while learning DOPs.
After having setup Vellum in SOPs I'm trying to import the setup in DOPs. At first everything is fine and dandy, but if there is a Transform added to the geometry on object level then only the GEO that's imported into DOPs network is updated. The Constraints are still in their original position. Is it possible to update Vellum constraint location when the object node is transformed?
Adding a basic example file with the issue.
test.hipnc
