Khal Posted August 2, 2019 Share Posted August 2, 2019 I am trying to use the color visualizer to colorize a topographic map, it is all working perfectly in the scene view, however, the render in Mantra is not picking up those colors and the render is only a single base color. Anyone could help how this can be done? Appreciated Khal Quote Link to comment Share on other sites More sharing options...
kleer001 Posted August 2, 2019 Share Posted August 2, 2019 The visualizer only shows colors for the display, as you've found out. If you want actual colors on your geometry use a Color SOP. Quote Link to comment Share on other sites More sharing options...
