ChazS Posted August 2, 2019 Share Posted August 2, 2019 The contours of the pictured font are guides to control the path of a knitting behavior. The idea is based on Entagma's PBD: Dynamic Weave tutorial where one set of contours are targets for the previous one, and so on... Since Manuel uses straight lines and I'm using curves, assigning a primID to each contour is a bit more involved than in the tut (he only has two points per line, whereas there are many more in mine). I'd like to somehow give each contour a unique ID of sorts. Does anyone have a suggestion on how to approach this? I've tried grouping by edges, but it's grabbing every line. And although it's kind of like inviting a vampire into my home, VEX answers are welcome too. Heck anything really Best regards. Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted August 3, 2019 Share Posted August 3, 2019 Is each contour is one primitive? If so i@primId = @primnum. Else if each contour consist of many then use a poly path sop to get one prim by contour. Quote Link to comment Share on other sites More sharing options...
ChazS Posted August 3, 2019 Author Share Posted August 3, 2019 3 hours ago, vicvvsh said: Is each contour is one primitive? If so i@primId = @primnum. Else if each contour consist of many then use a poly path sop to get one prim by contour. Thanks for response. Originally, I was creating these contours with a polyextrude sop and getting prims between each set of points. Which prompted my question. I then switched to a PolyExpand2D sop and didn't realize it creates a single primnum for each contour. Your response was a polite slap on the head to check my spreadsheet and to display primnums in the view window (doh!). I realized then I had what I was after. Your suggestions will now work perfectly. Thank you. Quote Link to comment Share on other sites More sharing options...
