zoki Posted July 11, 2006 Share Posted July 11, 2006 hi can someone answer me a noob question I really like grid and snaping to grid in network pane how do I save it to stay like this by default? thanx z Quote Link to comment Share on other sites More sharing options...
stevenong Posted July 11, 2006 Share Posted July 11, 2006 Hi there, There are two methods you can do what you're looking for: a. Edit the 123.cmd startup script b. Put the commands into a file and source it every time you want to turn on/off the grid and snapping What is the command to turn on Grid Lines and Snap to Grid? The command you want is neteditor (type "help neteditor" in the textport) and the options are: This turns on the Grid Lines display & Snap to Grid. neteditor -g 1 -a 1 name_of_network_editor_pane This turns off the Grid Lines display & Snap to Grid. neteditor -g 0 -a 0 name_of_network_editor_pane How do you find the name of the network editor pane? In the textport, type / -> pane pane1 -m viewer pane2 -m parmeditor pane3 -m neteditor Notice which pane is a "neteditor" and that is the pane you want to set the options. With the above example, the final commands are: Grid Lines display & Snap to Grid on neteditor -g 1 -a 1 pane3 Grid Lines display & Snap to Grid off neteditor -g 0 -a 0 pane3 Now that you have what you need, you can decide which method is best for you. Method a: Find the 123.cmd file in $HFS/scripts, copy it to your $HOME/houdini8.x/scripts and append the Grid Lines display & Snap to Grid on command above into the file. Please make sure there is an empty line at the end before saving it. Houdini should start with the Grid Line and Snap to Grid on every time. Method b: Create two files: grid_line_snap_on.cmd and grid_line_snap_off.cmd in your $HOME/houdini8.x/scripts directory. Copy the on and off commands into each file respectively. Again, copy the 123.cmd file into your $HOME/houdini8.x/scripts directory. Edit the 123.cmd & add your own aliases: ... alias SF10 'quit' alias F11 grid_line_snap_on.cmd alias F12 grid_line_snap_off.cmd ... Save the file, start Houdini and the F11 & F12 keys will turn on and off the Grid Lines display & Snap to Grid. I hope the above helps and please ask if you have more questions. Cheers! steven 1 Quote Link to comment Share on other sites More sharing options...
zoki Posted July 12, 2006 Author Share Posted July 12, 2006 uaaau thats and answer! thank you very much for this regards z Quote Link to comment Share on other sites More sharing options...
3dbeing Posted July 20, 2006 Share Posted July 20, 2006 wow! that was a thorough answer.... nice! now can you do the same thing for the gama in mplay, say I always want it set to 2.2 and if so can I get that code, or at least where to search for it... Thanks steve 3db. Quote Link to comment Share on other sites More sharing options...
