davidyannick Posted August 7, 2019 Share Posted August 7, 2019 I'm watching "applied houdini - particles 3" and I have an issue , lines are not copied If someone can explain what is the solution Thank you 05_brancging_loop_a.hipnc Quote Link to comment Share on other sites More sharing options...
ikoon Posted August 7, 2019 Share Posted August 7, 2019 (edited) Hi David, you may check the following facts. I am not exactly sure, what exactly should be the result, but this may help you? - pscale on all of your template points (right input of the copytopoints1) is 0.0, so even if something is copied, it is scaled to 0.0 - you copy only onto the "root" group, and there are only three template points in that group EDIT: - I just noticed, that you may also have a typo in the Group Create? "acCtive" Edited August 7, 2019 by ikoon 1 Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted August 7, 2019 Share Posted August 7, 2019 (edited) Hi, you forgot to set min max values of pscale attribute into the initial_params wrangle. Edited August 7, 2019 by vicvvsh 2 Quote Link to comment Share on other sites More sharing options...
davidyannick Posted August 7, 2019 Author Share Posted August 7, 2019 1 minute ago, vicvvsh said: Hi, you forget to set min max values of pscale attribute into the initial_params wrangle. Oh my god I'm so stupid, thank you so much Quote Link to comment Share on other sites More sharing options...
