Code for sequence and flipbook in mPlay ?
Hey there,
Here are the methods that houdini uses to create flipbooks ( https://www.sidefx.com/docs/houdini/hom/hou/FlipbookSettings.html )
To see what the current values are for a given scene viewer flipbook the best I could come up with was to query the setting and print it out like this
Quote
#in a python script sop
import toolutils
viewer = toolutils.sceneViewer()
curview = viewer.curViewport()
#just printing to check that the viewer is correct, assuming you are checking your current view
print viewer
print curview
curview_stash = viewer.flipbookSettings().stash()
#Here you can just specify the parameter that you want to check, you will have to check the documentation for the exact method that you are looking for
print curview_stash.frameRange()
print curview_stash.resolution()
print curview_stash.gamma()
Unfortunately it doesn't look like the flipbook stash returns anything that you can iterate over to print out an entire list.
Hope this helps
R
