How to suck a fluid using a straw ?
I'd strongly suggest faking it, if possible. Add an emitter at the end of your straw, so you've got perfect control about the amount of fluid flowing out of your straw. You could as well add a sink at some point where you want the liquid to enter your straw. the level inside the straw can easily be controlled in shading.
Thanks you I will try this...
