mike Posted November 22, 2002 Share Posted November 22, 2002 hi, has anyone an idea how to import a color/luminance variable from a surfaceshader into a displacement vopnetwork ?? The oppsite direction is no problem.( import displacement variable ). Quote Link to comment Share on other sites More sharing options...
stevenong Posted November 22, 2002 Share Posted November 22, 2002 Hey Mike, It only goes one way. You have to copy the nodes, up to the Luminance VOP, from the Surface VOPnet over to the Displacement VOPnet. Cheers! steven Quote Link to comment Share on other sites More sharing options...
mike Posted November 22, 2002 Author Share Posted November 22, 2002 thanks Quote Link to comment Share on other sites More sharing options...
Jason Posted November 22, 2002 Share Posted November 22, 2002 the reason is that in the renderer, the displacement has to be computed before shading - mainly because displacment affects shading while shading doesn't affect displacement. PrMan allows you to have the same shader do displacement and shading (you can displace in the Surface shader), but that isn't really recommended. Quote Link to comment Share on other sites More sharing options...
