Masoud Posted August 18, 2019 Share Posted August 18, 2019 Hi; What’s this button for, and what is its name? Is there any tutorial/example about how to use it? Thanks. Quote Link to comment Share on other sites More sharing options...
dgani Posted August 19, 2019 Share Posted August 19, 2019 I don't think it has a name - but the way you use it is, if you have two panes in different paths (for example, a network pane in /out/ and another one in /obj/geo1/) you can drag between them to set them to the same path. To test this out - pin the parameter window and then drag your network to the parameter. Quote Link to comment Share on other sites More sharing options...
Masoud Posted August 20, 2019 Author Share Posted August 20, 2019 9 hours ago, dgani said: I don't think it has a name - but the way you use it is, if you have two panes in different paths (for example, a network pane in /out/ and another one in /obj/geo1/) you can drag between them to set them to the same path. To test this out - pin the parameter window and then drag your network to the parameter. Is this like copying path from one network to another one? Quote Link to comment Share on other sites More sharing options...
dgani Posted August 22, 2019 Share Posted August 22, 2019 Yes, that's exactly what it does. Quote Link to comment Share on other sites More sharing options...
