pepemaracas Posted August 19, 2019 Share Posted August 19, 2019 Hello everyone, I've seen multiple posts and some discussion on regards to sprites, but most of it is from 8 or 10 years ago, so I was wondering if anyone would have some insight on a workflow or an example on H.17 for adding a looping image sequences to sprites. You must be thinking, "sprites? people still use those?", but the style I'm aiming to achieve relies heavily on some 2D animation. I've used some techniques with traced 2D sequences instanced into particles but for the sprites I am a little lost, specially when it comes to rendering the sequences. I've created an attribute for it based on the life $HIP/Sprite_v001_`padzero(4,round(fit01($LIFE,1,20)))`.png but not sure where to use it afterwards (shops have changed a lot in recent years). Also tried adding something to the Sprite Map on the popsprite inside dop: $HIP/Sprite_v001_`padzero(4,$F%40+1)`.png but still no success. Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
pepemaracas Posted September 6, 2019 Author Share Posted September 6, 2019 No one has any insight on this? Quote Link to comment Share on other sites More sharing options...
StepbyStepVFX Posted September 6, 2019 Share Posted September 6, 2019 (edited) Can you post a light version of your file so that we can see what's wrong with what you tested and understand better what you want to achieve ? In last resort, if you're lost with the POP Sprite, you can try to copy stamp or point instance grids on your particles after simulation, and simply put your sequence on the color map of your shader. You'll just need to be sure there is an orient attribute on your particles (use a POP look at node for example), so that it faces the camera. Edited September 6, 2019 by StepbyStepVFX Quote Link to comment Share on other sites More sharing options...
pepemaracas Posted September 9, 2019 Author Share Posted September 9, 2019 On 9/6/2019 at 7:26 PM, StepbyStepVFX said: Can you post a light version of your file so that we can see what's wrong with what you tested and understand better what you want to achieve ? In last resort, if you're lost with the POP Sprite, you can try to copy stamp or point instance grids on your particles after simulation, and simply put your sequence on the color map of your shader. You'll just need to be sure there is an orient attribute on your particles (use a POP look at node for example), so that it faces the camera. Expand Thanks for replying, for the time being I've done something similar to your last resort option, but since I couldn't drive the image sequence frame by the age of the particles I did it with traced geo based of of the initial image sequence, which is great for certain things. But this I feel is over kill for something as simple as sprites, so I really would like to find a way to do it with those. I've attached a simplified file of just some sprite fire attempt where I'm creating a string texture attribute to try and drive the material with. I appreciate the help. Sprite.zip Quote Link to comment Share on other sites More sharing options...
StepbyStepVFX Posted September 9, 2019 Share Posted September 9, 2019 (edited) Hi, I modified a bit your file ad it seems to work. I just created a string attribute spritemap with a popwrangle (using your fit01(age ...)), and in the spritefog material I used a bind node to feed the base texture map (see in the file). Just save the file in a place where your sprites are in $HIP/Sprite_v001/***.png (you'll see an error when Mantra tries to load the texture if you did not save it there :-) Hope this helps SpriteTest.hipFetching info... Edited September 9, 2019 by StepbyStepVFX Quote Link to comment Share on other sites More sharing options...
pepemaracas Posted September 9, 2019 Author Share Posted September 9, 2019 On 9/9/2019 at 7:42 PM, StepbyStepVFX said: Hi, I modified a bit your file ad it seems to work. I just created a string attribute spritemap with a popwrangle (using your fit01(age ...)), and in the spritefog material I used a bind node to feed the base texture map (see in the file). Just save the file in a place where your sprites are in $HIP/Sprite_v001/***.png (you'll see an error when Mantra tries to load the texture if you did not save it there :-) Hope this helps SpriteTest.hipFetching info... Expand This does help, thanks! Very interesting approach, so not really using the pop sprite. I guess for viewport visualization purposes I could link them all to the values on the material. I just thought the pop sprite would be a very straightforward simple node. Quote Link to comment Share on other sites More sharing options...
GDonkey Posted August 20, 2020 Share Posted August 20, 2020 Hi pepemaracas, Did you figure out a way to visualise this in the viewport ? I am also trying to drive a 2D animation based effect like this, and only being able to see the result in Mantra is not the way forward. There are so many applications for this using Houdini with 2D based effects but months later and I can't seem to get past this one thing. 1 Quote Link to comment Share on other sites More sharing options...
anthonymcgrath Posted November 23, 2020 Share Posted November 23, 2020 On 8/20/2020 at 9:40 AM, GDonkey said: Hi pepemaracas, Did you figure out a way to visualise this in the viewport ? I am also trying to drive a 2D animation based effect like this, and only being able to see the result in Mantra is not the way forward. There are so many applications for this using Houdini with 2D based effects but months later and I can't seem to get past this one thing. Expand +1 for this - i cant seem to render it in Mantra - i've got my own sprite sequence but is there REALLY no way to visualise this in the viewport? Quote Link to comment Share on other sites More sharing options...
anthonymcgrath Posted November 24, 2020 Share Posted November 24, 2020 found this tutorial on Vimeo by Peter Quint - it literally animtes sprite sheets in houdini's viewport if you cant see the link just look on vimeo for "mosaic sprites houdini 13" and go near the end to edit the vexpression Quote Link to comment Share on other sites More sharing options...
