Saya Posted August 21, 2019 Share Posted August 21, 2019 Hi, im using the prim expression to find a value from a primitive. but all primitives have different values and i want to polyextrude them accordingly. I cant use prim(surface_node, @PR, attrib_name, attrib_index). do I need to use this in a for each? or is there a faster less heavy method? Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted August 21, 2019 Share Posted August 21, 2019 Hi, on a PolyExtrude node there is tab Local Control. Use local attribute "zscale" for your task. I attached example file how to do this. exturde_prims.hipnc 1 Quote Link to comment Share on other sites More sharing options...
Saya Posted August 21, 2019 Author Share Posted August 21, 2019 so much faster!.. thanks! Quote Link to comment Share on other sites More sharing options...
