davidyannick Posted August 22, 2019 Share Posted August 22, 2019 I'm trying to model a spiderweb but how can I connect these points ? any idea please ? Thx spider.hipnc Quote Link to comment Share on other sites More sharing options...
jonidunno Posted August 22, 2019 Share Posted August 22, 2019 (edited) Just closed your add then added a polypath. Here you go: spider_v02.hipncFetching info... (oh and add a fuse after your merge before it goes into the vellum so makes it one object ) Edited August 22, 2019 by jonidunno 2 Quote Link to comment Share on other sites More sharing options...
davidyannick Posted August 22, 2019 Author Share Posted August 22, 2019 On 8/22/2019 at 7:33 PM, jonidunno said: Just closed your add then added a polypath. Here you go: spider_v02.hipncFetching info... (oh and add a fuse after your merge before it goes into the vellum so makes it one object ) Expand On 8/22/2019 at 7:33 PM, jonidunno said: Just closed your add then added a polypath. Here you go: spider_v02.hipncFetching info... (oh and add a fuse after your merge before it goes into the vellum so makes it one object ) Expand thanks Quote Link to comment Share on other sites More sharing options...
