Parameter Interface Toggle
Follyx
I have a control object for assigning colors/materials to each object:
now I want to include an on/off toggle for (de)activating all materials/colors via the interface dialog at once. Whats the procedere for it? Even a hint for a button wouldnt help cause I'm not able to program the neccesary callbackscript.
Thanks in advance for any suggestions.
  • 3 weeks later...
Hello,You can simply put this Python Code that i have made and tested with the same setup you have created.
Below is the Callback Script to deactivate all materials and colors via the single click or disable toggle with tick:
kwargs['node'].parmTuple('outside').set(' '), kwargs['node'].parmTuple('first').set((0.0,0.0,0.0)), kwargs['node'].parmTuple('inside').set(' '), kwargs['node'].parmTuple('second').set((0.0,0.0,0.0)), kwargs['node'].parmTuple('third').set((0.0,0.0,0.0)), kwargs['node'].parmTuple('burned').set(' ')
Note: Please change the parmTuple name according to your node name. This Callback Script i have tried with the same setup or control box you have made. It's working with both Button and Toggle checkbox also.
Edited by Vishal Bakhaswala
thanks a lot. I see, I should start with Python... but where to start outgoing from Houdini?
Sorry for the late reply, was busy.
Uhm, how I should integrate that? if I place a button on the control panel an paste the script (with parrmTuple changed to COPAN_CO_MAT (nodes name)) following error appear:
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
AttributeError: 'ObjNode' object has no attribute 'PANEL_CO_MAT'
any idea?
Edited by Follyx
